Sinners Saint
Ok I'm back with another issue. I searched the forums but can't quit figure out if my issue is what I think it is. I noticed here about a week ago that the truck would stall when I got on it hard sometimes. Also every once in a while it would die shortly after start just idling in the driveway. I thought maybe the fuel filter needed changing, so I changed it. Its still acting up and has gotten slightly worse. I noticed that when I'm setting at lights or just parked idling that the SES light would come on, but if I tap the throttle it goes off. So the code is not storing and I don't know if you can hook up a dianostic with the engine running on OBD1 trucks.
I was thinking maybe the LP is going out, I jumped it and it is putting out fuel through the filter bleeder. Does not squirt it out all over the place like it did when I did it the first time I changed the filter, but it does pretty well. Do these symptoms sound like a failing LP to you guys?
