SS Diesel Camshaft Kit
ccfoshee
Cedarville, OH
All:
Realize the reputation that SS Diesel has WRT injectors, etc.
However, seeing as I highly doubt they are grinding their own camshafts, has anyone had any experience with their "Performance Roller Camshaft Kit"?
Thanks.
We will do some searching later on, to compare it to the specs from a Delta 206 re-grind. We have never bought anything from SSDiesel.....j&j.
6.5TD Performance Roller Camshaft kit for all 6.5TD's in all trucks, all years
Model: ssd-849
Includes a custom ground performance roller cam, new hydraulic roller lifters, and a free tube of cam assembly lube.
Specs as follows...
Advertised Duration (Exhaust):300 Deg
Advertised Duration (Intake):260 Deg
Cam Lift (Exhaust):.281"
Cam Lift (Intake):.281"
Cam Timing at .050" Lobe Lift (Exhaust Close):17 Deg BTC
Cam Timing at .050" Lobe Lift (Exhaust Open):39 Deg BBC
Cam Timing at .050" Lobe Lift (Intake Close):11 Deg ABC
Cam Timing at .050" Lobe Lift (Intake Open):13 Deg ATC
Degrees Overlap:65 Deg
Duration at .050" Lobe Lift (Exhaust):202 Deg
Duration at .050" Lobe Lift (Intake):178 Deg
Lobe Centerline (Exhaust):120 Deg
Lobe Centerline (Intake):101 Deg
Valve Lash (Exhaust):Hyd.
Valve Lash (Intake):Hyd.
Valve Lift (Exhaust):.422"
Valve Lift (Intake):.422"
