drag sgt
Active Member
I've got 235/85s on my Suburban with 3.73s and need some opinion as to whether this is within normal error range for these trucks. I just did a 155 mile trip after fill-up and the trip meter is at 149.5 so roughly 3.5% under. Unfortunately, I forgot to take a pic of my regular odometer to see if was the same.
Second, my speed from various tools is a bit all over the place. At 70 on the speedometer, Google Maps registers 65/66 and Torque Pro through the OBD2 port registers just 63. I assume Pro is getting directly from the ECU and the speedo is pulling from the VSSB? If I re calibrate the VSSB should I expect the direct OBD2 readings to adjust as well, or will it just bring the gauge more in line with my actual speed?
