dually man
Well, I just got the 6.2 with a Ats turbo into my once TBI gasser K5 blazer. Previous history on NA 6.2 is: stock ip fuel rate, advanced timing by thickness of line on ip. dual exhaust and a 6.5 diesel electric lift pump.
NEW status of 6.2: Fuel rate turned up one flat of a allen wrench, timing marks lined up, ats turbo with 5" hood stack, stock EFI gas lift pump in fuel tank that runs 10 to 15 psi.
SO my problem is that my engine rattles more now after the swap, sounds advanced, I moved the advance lever and the engine fishbights real bad at idle. I get LOTS of black smoke at any throttle. I use my cold advance on a toggle switch so I can hear a slight difference in sound when that is activated. Should I retard my ip somemore? I been searching the forums for an anwser but cant find a simular situation....
