bison
I finally finished putting all gauges in my 98 today,
i put in a new LP.read a whopping 2.5 psi max press at idle and with engine off 4.Got 1/2 lb cruising Gawd.
That sucksIt was a spare, bought 1 1/5 yr ago.( no warranty left)And yes ,new tank,new filter,new everything.Now i have to dive under there to change that LP again.
pyro goes to 1100 degree in a heartbeat when i step on it,thereby the turbo gave me only 6 psi, at 2500 rpm, and this is empty and on flat ground . Next week i got to pull a 7000 lb trailer a 1000 km trough some pretty steep hills,makes me shudder what that is gonna be like.This is gonna suck.
Cat is gone,and i cut the restrictions outa the stock down pipe and welded some other pieces in.
