GenBiltstein
Active Member
- Messages
- 61
- Reaction score
- 106
Its all to common to see another 4L80-E transmission die off when they can last longer. They.were at the time were one of the strongest transmissions built for light truck duty. Other than the low/reverse band there were no bands to wear out or adjust and it's computer controlled. If you have a dependable 4L80-E on your hands there are things that you can do to help it last. Change out the transmission fluid and filter. I am old school so I will recommend a manual flush. That means dropping the pan and refilling the transmission case just more than several times over. This prevents a build up clutch crud in the torque converter, the valve body parts like clogged solenoid screens. In this case an ounce of prevention is worth a pound of cure. Contaminants in the fluid that are down to the microns can wear out pump seals, the valves and bores and similar components like the actuator feed limit valve that is susceptible to leaking because of side loading.
Give a once over on occasion like inspecting the passthrough connector for oil contamination because with these it will happen and its not if but when. The contaminated pass through connector can cause electrical shorting to take place right there at the connector. There are internal components that you can check with a multimeter set on resistance, and with the transmission fluid temperature sensor an infrared temp gun and a temp chart is all that you need.
Give yourself the chance to understand the 4L80-E transmission before it hits the ignore list and forgotten about until its too late.
