matuva
Tropical 6.5er
At the beginning of the week, my Blazer started being a bit more longer to start. Then I noticed engine was less "clancky", then cruise control quit working, and finally she stalls while gently cruising on the motorway. No SES light.
Yesterday evening, I put a new Flight system PMD + new extension to replace the grey Stanadyne PMD (6 months old) at the same place (relocated behind the grill)
My Blazer starts and runs fine.
This morning, on the way to work, I noticed that cruise control again quit working :skep:
At noon, back home for lunch, SES light came ON. She comes OFF as long as my speed is under 80 kph and or I stop accelerating. As soon as I touch accelerator and rpms go over 1200~1300 and or speed goes beyond 80 kph, SES stays ON.
At home, I hooked my scanner, and here are the codes I read :
I cleared all codes, went for a drive. 10 kilometers later, still having this jerky SES light coming On & Off...
I parked the Blazer, didn't shut off, and with engine idling, I got this:
So; DTC 41 let me know I have no more brake light. I will fix that.
DTC 35? PMD, resistor and extension are brand new, IP is a reman less than 20k kilometers, I always put 2 stroke oil in each tank ...
DTC 38? what's this switch? Where is it located?
DTC 84 and 99? Should I change the accelerator pedal?
What's your opinion on these codes?
This "idiot light" is turning me mad :mad2:
