Hello , my first post here.
I'm about to install a (factory) New FuelInjectionPump (DS4) on my 6.5. I see the new pump includes a PMD!
Should i dismount the PMD and re-torque the mounting nuts for the transistors, or is Stanadyne thought to be taking the Quality Control on their PMD production line a bit more seriously now ?
Background:
I bought my pickup used with 175kMi {a remanufactured DS4 had been installed proir my purchase}, re-torqued the driver mounting nuts per GMCTD's advice (@TDP) , added some Grounds and redundant series Filtration , ran in PMD configuration, and the thing operated flawlessly until it failed to start {actually- Started , stalled after a minute, and never since delivered fuel to injectors , despite ESO clicking nicely} some months ago , at 213kMi. I know the FIP had wear , since it would not maintain even speed at part throttle -- since i'd bought it. There were a couple occasions when the truck's engine 'bucked' and failed to get to full cruising speed , but those (consistent with advice provided by TurbineDoc@TDP) were due to a clogging fuel filter.
I have procured a Beta heat transfer pad , i'd just like to know if it 'remains' a good idea to tighten the transistor mounts...
-Thanks ,
Tom m
P.S. - i plan to post at TDP and Place , only need one good opinion {per poster!}
Background:
-Thanks ,
Tom m
