Smushed cooling fins, we all got 'em. I'm fixing 'em
great white
Canada's Ocean Playground
Yup, everyone's got 'em. Fact of life for a road driven vehicle. Problem is, I hate 'em. Get enough of 'em and it begins to impact cooling capability. Chuck in the fact that our trucks make beaucoup heat and there's a lot of coolers stuffed in that little area behind the grill and things start getting pretty bad pretty fast.
I recently made an attempt at preventing more of the rock dings and bug carcasses by putting a wire mesh behind the OEM grill:
Yup, that'll help but I've still got lots of smushed over fins in there. Having been told I'm a bit of a "perfectionist", it drives me crazy knowing that mess is in there and working against my goals. Not to mention it isn't helping the cooling situation any.
So, time to do something about it. I grab a cheap pair of needle nose from the local buck store on the way home from work and hit 'em with the grinder to make a tool to straighten/smooth the severely crushed fins. That, plus a pick and I have what I need:
Some might toss out the words "rad comb", but they're mostly useless in my opinion. Definitely useless in this case with crushed, wrinkled and severely stressed/distorted fins.
The process is pretty mundane, so I'll just do a quick before an after pic.
Before:
After:
The before actually makes it look better than it really was. That pict is after I worked the core a bit with the pick. Some areas were crushed in so bad it was like someone fired a marble at it with a paintball gun. The area that the fins look "wrinkled" was one solid wall of aluminum before separating with the pick.
With careful a cautious work, they can all be massaged back into their original position and then the stretched metal shrunk back into shape with the rad pliers fin tool.
That's the AC condenser core so it takes the most damage. It also offers the most blockage because it's right up front. With any luck, the AC performance should increase a tad as well.
Now, only 5,698,348 more fins to go......
Every little bit counts. I took my rad to the local shop where they boiled it out. It got the bug arses out of the fins. I then, fin by fin, began the task of aligning...fun fun.
You can't reprogram your OBDI to do that for you? On mine position #6 automaticaly straightens the fins:reddevil:
I used a nail file to straighten the fins. FREE. except for the time it took. That was two years ago, I looked at it recently and thought GEE, I'm gonna have to straighten the fins next year for sure. Thinking I might try some fiberglass pet screening material. Just wondering how that will affect airflow though. Seen it done with regular screens just never the pet screen.
as an AutoBody tech for many years,,, we had a plastic comb, that was used for this. It was faster, and did 8-10 fins per stroke,, But still not a fun job. try to go to fast, and slip,, and it's 8-10 cuts in one fell swoop.
While this is not a pict from my condenser core, it is what it looked like in many places:
In some cases worse.
Luckily, I did not have tube damage like the above, just fins.
No comb is going to fix those. Combs are good if your fins aren't severely distorted past the aluminum's yield point..
These were. By a lot.
They needed to be picked, bent and clamped to be straightened. Just like when you have to shrink metal that's been stretched.
Replacement is always an option, but it was still working fine and salvageable. A new one would have meant a new core and an AC service for around another 200 bucks.
For 5 bucks for a cheap pair of pliers, a bit of grinding, a couple beers and an afternoon of lazy work I straightened my condenser core, my rad core and washed it all.
It was tanked last year and runs dexcool, maintained (tested with a refractometer) up to snuff and a coolant filter.
No worries.
This was actually all in prep for another modification currently in the fabrication stage.....
Or call LMC.
True, they do offer one that is similar:
Similar, but not the same.
Holes are smaller, round fog lights, no bumper strip or "bumper-etes".
I don't like the "holes" on the LMC version, but that's just a personal opinion. Others may prefer the LMC version.
I actually use the bumper-etes on my truck as it's been known to be a "push vehicle" for a local guy's "special project".
I prefer the square fogs as they fit the look of the front end better than round (but again, that's just a personal preference thing, YMMV)
The rub strip? Meh, take it or leave it. I prefer it because it makes the bumper look more OEM.
I just prefer something that the average guy with a credit card can order up. Mine is "unique" without looking outrageous.
Still, the LMC version is a nice buy it and bolt it on option. If you like the style that is...
:cool:
