Hey guys, i got brought over from Dieselplace today...here is my post from over there...seems the talent is hyar now.
0. Describe in detail the problem you are having. Please be as descriptive as possible. BLACK SMOKE AND KNOCKING UPON ACCELERATION, ERRATIC ACCELERATION
1. Does the engine crank, or 'turn over'? YES
1a. Does the engine start and run? YES
1a1. If the engine does not start - Crack injector line: do you have fuel? Yes/No
1b. Do you have a Wait To Start Light & the amount of time (seconds) lit. YES...5 SEC.
1c. Ambient Condition (temperature outside indicate F or C) _____ ° 80 F
1d. Engine Cranking speed (if you have an accurate tachometer). NORMAL
1e. Are you experiencing stalling? NOT ANYMORE...YET
1f. If Stalling, describe (upon startup only, down the road, hit a bump etc) DOWN THE ROAD
1g. If Stalling, do you notice loss of dash or instruments? NO...WAS PMD HARNESS...SEE BELOW
-note if experiencing stalling,you must indicate PMD location in #24.
1h. Check turbo inlet and air filter for obstructions. Cone filters have lost disk and stopped air to turbo. ORIGINAL AIR FILTER
1i. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now? yes/no
1.1 Lift pump test - describe results LIFT PUMP WORKING PROPERLY
2. Service Engine Light while running?- on/off/intermittent NO
2a. Service Engine light does glow during start/cranking/bulb check: Yes/No DNK...WILL CHECK
3. Model year 1995
3a. Odometer reading (indicate if in miles or km) 195K...(WILL UPDATE PROFILE TONIGHT)
3b. Miles on major engine components if been replaced (example Injection pump) DON'T KNOW
3c. Indicate the model number on the Injection pump (starts DS4 or DB2......) WILL CHECK
4. Have you scanned for engine codes? (varies by pre/post 96) yes/no NO
5. List exact results on engine codes:
6. Air Filter condition (visual check) DIRTY
7. Fuel filter condition (freshly changed/condition unknown/mileage since changed) FRESHLY CHANGED
8. Condition of Battery terminal connections (removed, cleaned and tightened) CLEAN AND TIGHT
8a. Known condition and age of the batteries. 1 YR
8b. Are batteries of differing age or are they a matched set? MATCHED
8c. Condition of Major Grounds. (same drill as batt - removed, cleaned, retightened) SEEM TO BE CLEAN
9. Upon cold start, does the radiator hose get hard quickly? Yes/no WILL CHECK
10. Upon cold start, do you have excessive white smoke? Yes/no NO
11. Do you have excessive cranking time before the engine starts? NO
12. Have you used the block heater, and does this effect engine starting?(only try for starting problems) N/A
13. During hard acceleration, do you have excessive black smoke? Yes/no YES
14. Do you have any unusual exhaust smoke issues? SMOKES LIKE A TUGBOAT
15. Turbo check out - pass/fail PASS
16. Do you have an EGR on the engine? (An F or an S engine code 8th VIN digit) S CODE
17. Indicate if you know if it’s a 1500, 2500, 2500HD, 3500, 3500HD. 2500
18. Indicate fuel that you are using: Bio-diesel, #2 Diesel, #1Diesel, SVO/WVO, other #1 DIESEL
18a. If running a VO (Veggie Oil fuel) setup, indicate details of your conversion (homemade, or packaged system)
19. Are you using any fuel additives? If so, please list. NO
20. Please indicate geographic region you are in: (example: Texas or Canada) KENTUCKY
21. Do you have any service history available that might pertain to the problem you are having? NO
22. Please indicate any modifications to the vehicle that might help us diagnose better. ALL ORIGINAL
23. Upon unscrewing the fuel cap, do you have a large vacuum formed in the tank? yes/no NO
24. Location of PMD/FSD? On the pump/remoted over intake/remoted out of engine bay (please specify placement specifically) REMOTE...SEE BELOW
24a. If remote mounted, describe wiring harness (homemade or purchased from a vendor?) WAS PURCHASED, NOW JURY RIGGED
24b. Indicate the location and condition of the FSD/IP grounding wire. INTAKE MANIFOLD AREA
25. Are ALL glow plugs in proper working order as per this thread? YES
Per notes above, the PMD is a DTech with a Pensacola Diesel relocation kit in the front bumper.
Alright, so I had a diesel fuel leak for a couple of months (I know, but life's been hard since that ice storm down here this winter) and the truck started to smoke before I fixed it. It was leaking at the t-valve drain up by the front of the intake manifold.
Fixed the leak two weeks ago and replaced all flexible fuel hoses.
anywhoo...it was starting to give off some black smoke which got worse over time. After i replaced the fuel hoses I had it stall on me. Wiggling the pmd harness fixed the problem. then it happened last friday on the interstate away from home. I plugged in my old PMD into the original harness and managed to get off the interstate into a Walmart parking lot.
long story short, i unplugged the Pensacola Diesel harness where it plugs into the original harness on top of the intake manifold and there was a pin burnt out on both harnesses. I don't know if it got diesel in there during the leak or what, but it was definitely malfunctioning at the harness connection. I cut the plugs off the harness and reconnected the proper wires together with wire nuts and tape and off we went with no problems. The black smoke even went away temporarily.
then the smoke started to come back same as before...it smokes black at idle, it smokes pretty good under high torque, low RPMs, and if you mash the gas pedal it will give you a getaway smokescreen that frightens the folks behind me. And it knocks pretty good at low RPM acceleration loads.
I took the harness apart where I "repaired" it and the wires seem to be fine, the harness plug is fine at the PMD in the bumper.
I plugged the old PMD in under the bumper and the issues stay the same.
Any help is much appreciated and I will be sure to finish the checklist tonight or in the morning if there's something I missed.
Thanks again!
__________________
1995 K2500 4x4 6lug 6.5TD "S" Engine Extended Cab Short Bed 197000 mi...
3. Model year 1995
Thanks again!
__________________
