Matt Bachand
Depends on the 6.5
HF has these on sale for $11.99. I picked one up today, but might get another for the other battery too.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=99857
It comes with a bracket that you can mount on the firewarll, OR slides under the battery to mount ON the batteries face.
Being on the face, any heat from the charger would help warm the battery.
It also comes with copper eye hooks on the outputs to permanately mount onto the battery.
I figure when plugging in the block heater, giving the batteries a small charge/trickle will only do good.
Its a 3 stage charging system where it will charge battery at 1.5 amps, then top off batts at 200mA, then finally a floating trickle where it applies small ticks of charge to maintain.
Can't beat the price, or the confidence this will give you in the morning.
