Should I try & move the IP or not, what say you?
Crankme69
Illinois the Corruption Capitol of USA
Here is where my timing ended up at after doing the TDC set & learn.
INJECTION PUMP SENSORS
Actual injection pump timing: 28.78 Deg °
Cam reference missed: 0 Counts
Crank reference missed: 0 Counts
Fuel calibration: 120 Counts
Fuel rate: 7.5 mm³
Fuel rate - Cruise: 0 mm³
Fuel rate - Idle: 7.81 mm³
Fuel rate - Maximum transient: 42.5 mm³
Fuel rate - Throttle requested: 0 mm³
Injection pulse width: 1.66 ms
Injection timing - Measured: 6.9 Deg °
Injection timing - Desired: 6.9 Deg °
TDC offset: -0.18 Deg °
I'm wondering if I should battle the IP gods to attempt & move that sucker or just leave it where it is?
I have never tried this, do not have the custom bent wrench and would appreciate what I would be leaving or gaining by getting to -1.5ish offset?
TIA
I would recommend it. You already have the scanner it seems, so make/buy/find some IP wrenches, and give it a go. I noticed a good difference and I stopped at -1.38. You will also learn alot about your IP and other areas too.
Come back and get some hints just before trying it, CrankMe... The guys are pretty good at not letting us forget any of the details we need to remember!
Will do thanks!
I will comment that it appears that reducing the TDC offset from my original findings 0.35 to my updated -0.18 has helped reduce most all of the diesel "PING" that I would here under light acceleration and it does also seem to be starting with less drag on the starter in the morning…
I am not sure if these observations can be backed up or negated with facts? But it does seem to run quieter when at normal operating temp.
No change in performance / acceleration, it has always moved out and run very well since I fixed the OPS & LP right after purchase.
Oh and it does have a chip, just need to look & see what one is in it, it's not stock...
That GMTD scan is really KEWL!
