Shocks for new suspension
Status
Not open for further replies.
BigBlueChevy
Compression Ignition Addict
Pennsylvania
Nick I have a question for you.
I'm going to need to finally order shocks for the rear of my truck after the SFA swap has been mostly a success and the rear is now leveled out. What kind of shocks would you recommend?
Dimensions are as follows:
-Sitting unloaded there is 27.5" between the axle mount and the frame mount.
-with the axle "hanging in midair", there is 43" between the axle mount and the frame mount.
-The bore in the axle brackets is 9/16"
The truck spends most of its time unloaded but I do pull trailers on occasion. As well as load the bed down with everything from tree's and brush, to full pallets of pavers.
What do you recommend given this info?
Status
