Service Manual
SnowDrift
Ultra Conservative. ULTRA!
Central Ohio map dot
Are the older GM Service manuals still accurate for the later GEP engines? In particular for re-assembly for having accurate torque specs. on rod bolts, bearing clearances, etc.? This is in regards to the engine I have now which appears to be a 2011 model.
I wonder how many errors are present aside from bore. Is that all that was found to be in error or switched?
