Service engine soon light
Peewee21
Missouri
My ses light is normally off but yesterday it came on when i got up to 75mph so i let off the accelarator and it went back out any info would help. Thanks in advance
Pull the codes. Use a paperclip and take/post a video if you have trouble reading them out.
I've cleaned all the grounds and cleared the codes then drove it down the road and back about 3 miles and checked again and it didnt show any codes coming back up
Code 78 is the one that caused your light to come on at 75. My BURB did the same thing when the boost solenoid went out. It wasn't constant, but something about that speed seems to trip the 78 when theres even the slightest boost issue.
It can be MANY things cause the code 78. Vacuum pump, broken vacuum line, vacuum solenoid, boost pressure sensor, plugged air filter, rotted out exhaust crossover, turbo, wastegate actuator, plugged exhaust from a crushed pipe, or even an ECM could cause a code 78. Code 78 just means actual boost is not what the ECM is commanding it to be, so you have to diagnose it to see why it isn't.
