North Maine
Merchant Mariner
I know that compounding turbos is usually used to just make huge boost pressures, which obviously is not anywhere a 6.5 wants to go, but would it also allow you to operate a turbo inside its efficient parameters and get more PSI/flow? Here is my idea...
6.5 with 18:1 compression ratio running a centermounted hummer GM-8 with mechanical wastegaste control that is quite light, as in if it were just that one turbo it would yield about 4-5 PSI under full load... have that GM-8 feed another turbo like the ATT on the pass. side, intercool, and into the engine.
Is this just a really stupid and expensive idea?
