M123KT-450
- Messages
- 442
- Reaction score
- 0
Ok up date guys i ran the same trip this weekend as last weekend only difference is i ran in 4th gear the whole trip, towing a smaller single axle trailer towing 2 ATV's instead of 3 units on the tandum axle car trailer towing in 3rd. . .truck burned the same amount of fuel round trip 3/4 of a tank so the fuel milage from 3rd loaded heavy and running 4th loaded a bit lkighter had no difference on fuel milage. but instead of just running just under 200*F water temp it ran 210*F the whole trip. so single axle trailer n 2 ATVs was about 40% lighter. . .So why did it burn the same amount of fuel ? why did it run a hotter water temp ?
I was hopping to see it run cooler or get better milage but neither happened it ran a little hotter in 4th gear towing lighter then 3rd towing heavier, It also towing the lighter load in 4th gear burnt the same amount of fuel as running the heavier load in 3rd gear. . .
Trip 1:
3 ATVs tandum axle trailer, 3rd gear running 65mph@3,000rpm water temp 197*F 3/4ths tank of fuel 275miles.
Trip2;
2 ATVs single axle trailer, towing in 4th gear running 70mph@2,400Rpm water temp 210*F 3/4ths tank of fuel 275miles.
please do explain i feel like i am going Crazy here as the fuel milage was the same and the water temp ran 13*F hotter towing in 4th gear with less load. . .is there some thing wrong with this truck ?
Mikey
Trip 1:
Trip2;
Mikey
