docdray
Oompa Loompa
heres the deal, truck in sig line. last oct did 97 coolant upgrade and duramax fan, externally cleaned rad and condensor.  just hauled measley 7k lbs in 105 heat. truck empty runs 185 degrees but this weekend ran 220 degrees flat ground under 2500 rpm at 64 mph or less 750 to 900 egt. over 2500rpm it ran 225 to 250 degrees steady with egt at 815 to 1100  flat to mild hills. Is original rad, I am going to pull and vat the rad, is it possible it needs to be replaced, is the fan clutch adjustable, any other reasons it is running this hot besides bad radiator? boost is running 7-9 psi. even b4 upgrades it ran 220-230 pulling loads.
