running with the turbo off. Supply line?
jrsavoie
Recruit
Rural Clifton, Illinois
What do I do with the supply line to run the truck with the turbo off?
I'm still looking for a leak on the 96 Suburban and want to run the truck with the turbo still off.
What size is the compression nipple on the turbo?
Can I run an open line from the turbo supply line to the oil ifll tube?
Can I plug the tubo supply line with a compression plug?
Thanls
Jeff
Can the line run unrestricted?
What size is the male comression? Is it a standard size?
can I plug the line with a compression plug?
Thanks
Watch the oil pressure, it should be OK. If oil pressure is too low Slim Shady or Patrick should know the fitting size. I know I've seen it on here somewhere.
-6 AN 45 degree. Get a plug and plug it. The turbo serves as the 'restriction' to keep the oil pressure UP in the system.
