miltowndiesel
- Messages
- 3
- Reaction score
- 0
I bought my truck not running and took it to the local deisel shop to have them check it out. the OPS was bad and once it was running they said it had a lower end knock. Assuming it needed a motor i towed it home. I put a new OPS in it just so i can move it around without pushing it.
Now that is running i can hear the knock myself. It doesnt seem like a rod knock to me. I think it just needs injectors. Upon start up it puffs a little white as if you had some bad glow plugs but not as bad and continues to slightly puff white during idle.
Also the oil pressure is a little above 40 at idle. This seems odd to me. Ive never seen an engine with a rod knock hold that much oil pressure at idle. Could it be that i may only injectors? There is also a cylinder imbalance on number 3,4, and 7. What do you guys think?
