- Staff
- #1
Well after my trip back from La, I have decided it's time to do something about the rear suspension of my BURB. She rides great without a trailer, but with my travel trailer in tow it gets pretty squirrly when I pass or get passed on interstate and this resulted in a bit of an experience for my wife on the drive home. I've gotten used to the squirrlyness when getting passed or passing, so I'm always ready with the trailer brakes to pull her back straight. I've decidsed when funds allow I'm going to put a set of 2" steel wheel spacers on the rear to correct for the narrower rear track than the front. I'm undecided though for what to do about rear sway control though? I can pick up a rear HELLWIG sway bar for about $180, but I keep reading about the Roadmaster active suspension system for $350 and can't decide if it is justifiable to spend the extra money or not on one? Then there is alway the option of going to a junk yard and getting one off of a 1500 BURB, but by the time I build the brackets and replace the bushings I might as well have bought the HELLWIG kit. I've also read about a few people saying the HELLWIG rear sway bar has caused frame cracking as they don't really use a very good atatchment point with there add on kit(they use just one bolt hole in the bottom of the frame whereas the factory kit used a suppoort bracket that distributed the load out for about 10"s of frame), and this brings me back to the Roadmaster kit.
So my main question is, is the Roadmaster worth the extra money?
