BigBlueChevy
Compression Ignition Addict
During a phone call with Tim,(Turbine Doc), we got on the subject of modifications to the suspension that improve your load carrying capabilities. Of course, air bags where mentioned, but another item that was mentioned was the Roadmaster Active suspension. Curious enough about it, I went and purchased the unit from my local Hecht Trailer. Now, the unit itself is designed to be mounted on the rear leaf springs, and works in conjunction with you leaves in order to provide great load carrying capabilities, without the need of air compressors, weak hose or bags that get damaged for being under inflated. Its a simple bolt on kit(took me about 4 hours to install, and most was BS cleaning up dirty parts and repainting them. More than likely, I couldn't see it taking more than an hour for average Joe. Theres no need for any fancy tools, no massive wrenches, no cutting, no welding and no drilling. Aside from there latent ability to absorb load instead of try and resist it, it also completely eliminated my body roll(no sway bar). I'm EXTREMELY impressed and pleased with the kit. I'll be buying it for the rear springs when funds allow. To hell with air bags- these things are so much better and more convenient.
