Mr Baadboy
yesterday while putting my Camper in the driveway for the first time since the move 6 months ago. The drive is a slight grade and narrow....but the street is steep about 25* while baacking up the hill and backing in to the right i could smell my clutches, backing down is not an option. There are two drop off's both sides of the street and a steeper drop Ditch on the left side of our drive.
Anyway after searching the reverse gear uses the 3ed and 5th clutch packs that in itself explains alot the tranny has 234 k and who knows how abused it was before i got it 196 k. Plus i forgot to unload the predator 85 hp setting.
Did not put in 4x4 because tight turn and bone dry...............
Should I be prepared to drop in the full Transgo to solve the problem or should i just replace all 5 packs.....YOUR THOUGHT"S and SUGGESTION'S
greatly appriceated.
