DieselSlug
Figured id try a write up on how to do this since there wasn't much out there for me. First i started with removing the plastic center cap.
Next was to loosten the spindle nut , it is a 35mm, however i used a 36mm and it seemed to fit better.
Loosten the lug nuts, then jack up the truck and support with jack stands for safety.
Remove the lug nuts and pull the tire off.
Remove spindle nut the rest of the way.
Next is to remove the caliper, it takes a 3/8'' allen wrench, i went out and bought a lisle kit from Sears, comes with 3 common sizes as sockets for $7.99. (Good time to grease sliders and check brake wear)
Prop the caliper out of the way, i had it resting on the top of a cinder block to relieve strain from the rubber line.
There are 4 bolts that hold the hub assembly on the spindle, they are located on the back of the spindle. They are all 15mm in size.
Once they are all removed you are going to have to pry the hub assembly out of the spindle. This can take some time. I used a few crow bars and some large screw drivers. Turning the wheel both ways allows you to get at the front and the rear. You can see the seam where the hub meets the spindle, start by hitting the driver or bar into this seam to force the two apart, once there is a bit of a gap you can grab both sides of the hub assembly and pull it all the way off.
Next is to remove the pressed in studs, sed the rotor on a table with studs facing up, grab a lug nut and thread it on about 1/2 way or over to the stud. Hit lug nut square with hammer several times and it will push the stud out through the back. Remove lug nut and thread on to next stud. Repeat for all 8 studs.
Next we have to get the hub off of the rotor. Grab some pieces of wood, i used two 4x4's and place them so the rotor rests on them like in the last picture.
Continue on next post.........
