replacement head lights
chevyCowboy
Springfield Nebraska
I bought one of those from the bay a couple of years ago, not from the same seller for about $100 shipped, so price has gone down a little.
It works on mine, I just installed the lens use the existing bracket which is easier to do.
I have not put on the side markers, though.
think im ganna order a set mine arent very bright and i drive alot of county roads and even with my brites on it aint to good think it has alot to do with the fact that they are not very clear i dont think they ever where but mine are almost like smoked glass
I recently bought a set like this from ebay... Make sure to use the stock mounting brackets if you can. theirs are flimsy. Mine broke while I was trying to adjust them. I just swapped the stock ones back. They were alot brighter than the factory ones as the lense seem to be clearer than even brand new factory ones and the reflectors are much better.
I also bought a headlight polisher kit to fix my old ones. the one I used was from McGuires. It worked pretty well. it comes with a polish pad that fits a drill. only took a few minutes to do. Doesn't get them perfet but it looks alot better than before.
The headlights are the same, but the parking lights and the corner lights are different, so you could just sell them off and come out with a pretty good deal on headlights!
88 and 89 had 4 head lights, 90-93 had smaller corner lenses (chrome of the grill rapped around them) 94 and up had the larger corners
makes sence y Lmc only haas on then they are jusat selling the head lights no markers and personaly i think i like the amber markers better any way they match my cab lights.
i found another set by the same seller that are for 90 to 93 so i guess i will get those in case i want the markers unless soome one wants to buy the markers from me i will get the later set
Josh I have a set out of a 90 if they will work. A little hazy but I don't think they are cracked. I will double check after work today. I also have the side lights and reflectors too. Let me know, sorry if I am too late.
If you get those lamps,, also get some Sylvania Ultra bulbs, and the get a Mr Headlamp kit to make you lows, stay on when you hit your high beams,, I have only the Mr Kit, and my lights are great at night! dirty lens with factory bulbs and all!!
I bought a set off EBAY of the projector replacements with LED bumper lights. The quality was HORRIBLE to say the least. The headlights are flimsy and I had to cut my radiator support for them to clear as well as the stock mounting brackets. The LED's were wired backwards and one of them had the resistor inside hooked up backwards and almost caught my light on fire from it. Also one of the corner lights was molded wrong in the mounting tab so it is crooked pretty bad. You get what you pay for with these I believe. On a plus side though, the LED tailights I got work pretty good though.
Yikes that is bad, your right about getting what you pay for, my LMC ones were actually pretty nice, I could tell they weren't OE, but the fit very well and adjusted out fine! But they were 90 bucks a side.
joe let me know and maybe shot me a pic or two if you can i may try that and the MR headlamp kit and better bulbes mine are so hazed over i cant even see the bulbes in the day light
Pruittx2, where did you get the Mr headlamp kit? Price?
THEFERMANATOR i was looking at thos but decided i didnt like the LEDs the ones im looking at look pretty good. ganna see what the ones joe has are like other wise im ganna try them
Ok got some pics I'll get them out on a PM for you prolly around 10 am (my time). Joe
