What is the gph rating of your airdog?
150 gph.
I see the filer # for the AirDog is FF100. Its about 16.00 a filter from what I can see. Would be nice to find another filter to work for it.
Did you ever change yours out?
On the AirDog and FASS 95's, you can go 15K on the filter and 30K on the water seperator.
On the FASS 150's you can go 25K on the filter and 50K on the water seperator.
When you change the fuel filter, just rinse the water seperator with a bit of clean diesel and reinstall. Unless it's nasty, you can re-use it. It's only a wire mesh screen and rated at 144 microns, so the only thing it really stops is water, sticks, bugs, big dirt clods, etc.
One thing I usually recommend to folks in colder climates is the run the 7 micron filter in the winter an the 2 or 3 micron filters in the summer. Only reason I say that is I've seen guys have issues with clogging due to fuel gelling in the 2 & 3 micron filters.
