I just replaced my IP with a reman from pensacola. My PMD is on the front bumper. Just got done pulling from Redding, temps outside were in the high 90's to 100. I pulled over and the truck sat for about 15-20 minutes and when I tried to start it again, it cranked for probably 6 or 7 seconds and then fired.
When its cold it fires right up.
I replaced the IP because it wouldnt start hot unless I dumped a bottle of water over it, then it would fire right up.
Other than that, the truck ran a lot better now that I have the GLE chip in it. I'm running sustained up a hill about 9lbs of boost, and on the flats about 5 lbs, towing a 12k fiver.
b
b
