Burbanaz
Ok im not sure which direction i really want to go with my engine. I want to stick with the 6.5 but i dont know if i want to try and rebuild the engine i have now or replace it with a military take out. I have a 94 k2500 suburban so im not sure which block id be starting with or if its even a block worth trying to rebuild. It runs fine but its feels low on power, starts to overheat during hill climbs, and i have to add coolant every 100 miles or so. Plus little the little leaks here and there that just come with age. So i know at minimum i have to replace the head gaskets.
The engine has 205k on it, so if im going to go through the work of replacing the head gaskets im going to pull the whole engine, replace head gaskets, freeze plugs (because i have one that was leaking), injection pump (getting codes 35, 36), glow plugs, injectors. Not sure if i should re ring it or not. Should i just do the headgaskets and the minimum amount of stuff or replace everything i can while i have the engine out?
We go on long offroading trips into the middle or nowhere and i need it to be as reliable as i can get it.
So basically im trying to decide if im going to tear this engine completely down and rebuild the whole thing and try to make it as strong and reliable as possible, or replace it will a military take out. What do u guys think? which would make the most sense money wise? and can i even make my engine more reliable or is it just a problem waiting to happen?
Heres a pic of my truck just because lol
