aschooley
I bought a 84 basket case a few months ago. I was hoping all it has wrong was a dead lift pump and some other maintenance issues, like bad batteries and fluids/filters. I replaced the lift pump with another mechanical one and replaced the filter. It took a lot of cranking and wd-40 but I got it started. Now that I proved it would run I started putting some money in to get it road worthy.
I have replaced all of the fuel line from the lift pump to injection pump with clear hose and I am getting flow back from the fuel filter back to the tank, the hose to the injection pump stays solid with no air. I have pressurized the system from the return line and can't find any obvious leaks, the thing is so dirty and full of every fluid everywhere, unless it was a gushing leak I don't know that I could find it either. It drains back really quick though. Within 5 minutes the hose from the lift pump to the filter is completely empty (I bypassed the hardline)
I read somewhere that newer lift pumps have a check valve, I replaced mine with whatever carquest had in their system, most likely without one. I have read that the Stanadyne housings can crack enough to let air in but no fuel out, especially around some of the sensor housings in the back.
Rather than messing with it any more, (I already spend $50 on two new plastic air bleed screws), should I just rip the whole thing out and put in a Racor 10micron filter/water separator? If i do should I put it between the two pumps like the factory unit or should I put it before the lift pump? What flow rate should I look for?
Thanks in advance.
Thanks in advance.
