I found that driving up on blocks wont work because you have to get the exhaust past the axle. you need to get the frame up and let the axle droop. I used a jack and picked the truck up by the hitch. slid right out after that. and if I recall I went forward with it.
:rockon:
WD 40 and channel locks worked for me. Hook one side behind the rubber and the other on the end of the hanger,squeezed the pliers and it slid right off. .........
