schiker
I googled and saw one tip to use Ammonia to remove RTV. Permatex also makes RTV remover. I usually just scrape, scrape, and scrape. WD40 scotch bright scour then brake cleaner to finish. What do ya'll do?
I tried some permatex gasket remover and it seemed ok but you still have scrape off excess gasket first if the gasket is thick.
What about Anerobic sealers like the Right Stuff. Any removers for those?
