Woody35
Active Member
any venders sell that on here thats easier to mount the oil filter because of 4 wheel drive
Or you can build your own...
Perma-Cool spin-on adapter on block and Perma-Cool dual remote mount on A/C bracket. Safe in engine bay from road/off-road hazards/debris.
You can install just about any spin-on oil filter that will fit. I use stainless steel washable 22 micron oil filters.
Use a good size diameter hose (to prevent laminar flow and decreased flow rate), stiff as you can get to prevent bulging under pressure (pressure will drop), only as long as needed (setup will still increase your oil capacity).
Regards,
Franko
Where do you get stainless washable oil filters? Can you get finer that 22 micron?
