Dan Hunter
Truck Terrorist
Geez, it's been forever since I've been here largely because it's been forever since the truck misbehaved. In fact, going to work I thought to myself how reliable it's been. That was a mistake.
On the way home, the voltage was well below the normal indication and would dip when the turn signal operated.
I pulled over and checked the terminals giving them a bit of a twist. No help. I got home and cleaned the terminals even though they seemed serviceable. I put the charger to the passenger side battery and it would take no amps. The driver side pulled 6 amps. The interconnect NOW is showing continuity but of course that's no assurance that I had continuity earlier.
Can someone remind me how the charging works? My recollection is the driver side battery receives the charge and the passenger side provides the power. If that's correct, wouldn't a poorly charging driver's side and a fully topped off passenger side indicate a bad driver's side battery?
