Release Bearing Throw
ham7944
hello to all!!! it is monday morning and i am sitting in blind river ontario just west of sudbury. i have just travelled across for the west coast and late last night my truck for some odd reason now will not release the clutch. i seem to have less pressure at the petal but no noise. i can bump it into gear and power shift so i know the clutch is fine but maybe the slave is leaking by. i can visually look and see the fork moving with no issues but i dont know if its movign far enough. does anyone know the distaance this should travel in inches of mm from petal fully realeased to petal fully derpressed????any input would ber great as i am about 5 hrs from where i need to b!!!
Could you get a little more travel by possibly removing padding or floor mat behind clutch peda l?
prolly already did this but check fluid level. Could also be the pilot bearing is binding up not let the input shaft stop turning from the flywheel. need alittle more info..........year, etc.....
Could be a # of things.
As been said,leaking slave.
Piece of clutch lining came loose and doubled up between the pressure plate and disc.
pivot ball wore trough the fork.
did you loose pedal travel?
