hookedup50
I'm redoing my interior over from headliner to carpet. When I removed the rear seat the other day it was soaked bad and is probably the cause of lower cab rot. It was not noticably leaking like this until recently. I suspected the third brake light gasket, but taped that area over with plastic last night to rule of or determine cause of leak. Today the monsoon arrived as expected and the window gasket appears to be the culprit. Has anybody has this happen and what did you do to fix it. My first thought is to put a bead of windshield sealer into the gap after cleaning the area. Why can't I own one vehicle that doesn't need dash removal and has leaky windows(Sorry for rant). Thanks.
