Rear Blinker Assembly - Socket Problem
Matt Bachand
Depends on the 6.5
Worcester, MA
I have this rear light. The bulb with the cardboard shimmed is the culprit. Left directional. Anyone know if I can just buy this orange socket pre-assembled as it comes out easy and plugs into the pin port. The wires coming off it simply pins that plug into a 6 socket plug inside the light.
The wires are coming off breaking off the inside weld contact. The inner sleeve is off factory mark making it lose contact, it would be easy to just unplug it and toss a new one in.
I'd like to swap entire units with LED's but having trouble finding them.
Its location makes it a HUGE pita to work on. Cant get your hands in there, only finger tips...
Between that ladder, liscence plate... its frustrating. You can see it, and touch it, but can't work it.
I moved this to Electrical. Probably a better response here.
No prob to find LED versions around here...
Jetco lighting is the manufacturer that I usually use for any sort of lights
It'll most likely be more than $15 but they have been good for me
Part# 127-66094 (right) / 127-66095 (left)
On Edit...just realized that they are mostly just Canadian distributor...
