matuva
Tropical 6.5er
Recently, my Blazer was hit on passenger side by a M****r f*****r who was exiting a parking without checking if somebody was coming...
Had it repaired and repainted at a body shop, but now, it seems that the rear axle tube shaft is possibly bent on that side, and the drivetrain can't be properly re-aligned.
Mechanic says this can't be repaired.
So, I believe I need a new rear axle :mad5:.
According to VIN, I have a 10 bolts GT4 AXLE,REAR,3.73 RATIO 3.73R(GT4).
Question is: can I use a rear axle coming from a K1500 truck, a 14 bolts, as long as I have a GT4 3.73 ratio?
Somebody already did that? Plug and play or some mods to do.
May be should I take the opportunity to swap to a 2000 silverado (gasser) with brake disc if I need to modify somthing anyway?
