Rear axle / parts swap
Norway
Hi.
Is the 10,5" freefloating rear end from a K2500 pick up fit in place of the OEM Tahoe rear end? And if yes, possible to swap in the front diff and front suspension from the same truck at the front end? Hubs, driveshafts etc????
Thanks
You can swap rear axles, but parking brake cables will be different length and you might need a different ujoint.
I would think the front could swap out to but have never done it.
Hi.
Thanks. I assume the diff will fit in, not sure if the hub, cv halfshaft and rotor does?
Different lenght on the rear driveshaft?
Anybody?
