Rear Axle Compatibility
nobby
Old Timey Diesel Guy
Long Island NY
So i picked up on some website possible differences in the FF Rear Axle in that a company listed install kits for 1988-1997 and then 1998-2017. I was assuming that this more an internal thing. However i am looking at axle swapping the donor is a 1999 Suburban Full Float, will this be a direct bolt into my 1997 that currently has the 14 bolt semi?
Cheers
Nobby
If it was a 2500 suburban, it may have the 3.5" rear shoes which is a nice little upgrade as the 2500 pickups only had the 2.5" shoes. As Doug suggested verify that the spring perches are the same width which I think they should be. I swapped the rear end from a 1999 2500 onto my '95 2500 with no issue so you are probably good to go in terms of frame geometry.
