NickBarrFishing.com
Hi,
I have been trying to figure this out...so here is my problem.
I have a 1995 3/4 ton with a 5 speed NV4500 with about 150K miles on it.
I go to start the truck, and sometime its starts right up, other times, I turn the key and I hear a big click and a bunch of little clicks afterwords in short succession.
My voltage is good. So I got it up on the lift, and I checked the grounds, all the grounds i could find were clean and well. The connections to the starter solenoid seemed in good shape and their grounds were good (Couldnt find where the small ground wire that leads up into a wiring harness went too though??)
So here is what I found.
>I can start my truck in neutral w/o the clutch being in? Is this normal for this truck, I have heard you can snip a wire and be able to start w/o clutch pressed
>Tapping the starter and solenoid did not help
>Starts at random times, ten tries, then it will start, or one time (How it is supposed to be), sometimes I have to push start (Pain in the arse)
So if my grounds seem to be ok, my gut tells me it is the solenoid. Anybody else have any suggestions?
I am in High School and taking advanced auto, so I know my way around an engine, but I am just starting to dive into diesel mechanics. Fishing is my passion, and hopefully future business path, but diesel trucks is my new found hobby, so I figured the truck I got would be a great beginner diesel.
