Radiator cap
SnowDrift
Ultra Conservative. ULTRA!
Central Ohio map dot
Silly question on a Radiator cap. For what year do I order? 95 truck using 98 style bottle. Couple different ones available.
With ears which is what was on the tank when I got it. Pink label also shows up for that year but I don't know what that means, nor does the dealer.
Check the pressure ratings between the two year. If the older truck has a lower pressure rating then get the cap that fits the 98 but at the rating of the 95.
I think both caps are the same on latching and pressures.
I dont rememer what the PR is on my 2000.
Might most possibly be a 13 PSI.
