The main thing is not to have the filter restrict the flow is all.
Extra capacity in the filters ability to allow fuel flow will not hurt anything.
The Racor 230R2 is a physical size that can be mounted under the hood easily and in a place that allows easy servicing.
My Racor is mounted on a custom bracket using the two front bolts of the ABS unit on the LH side front.
The Racor sits right alongside the alternator on the 95.
When checking the oil one can shine a penlight at the bowl on the filter assembly and see if there is any water or crud in it.
The main things are having enough capacity, being able to mount the thing easily in a place thats secure from damage and easy to get to without having to crawl under the truck.
Also the filter will stay warm in the winter with the block heater working and or during driving.
Beauty is that it takes a spin on cartridge.
I keep a spare bowl in the shop and when I need to change filters I swap the filter and bowl then remove the bowl from the old filter and clean it before installing it on a new cartridge and placing it in a clean plastic bag, ready for next time.
If Im traveling I take my spare and place it behind the rear seat. JUST IN CASE
MGW
bought the kit that Racor makes for the DMax. Included WIF, heater and wiring harness to tie into factory system.
