Bad BowTie
How can i tell if it is good
I personally don't buy into the whole if it's 5 years old it's bad myself. Mine is almost 6, and still locks in just as solid as it did the day I put it on. If it's leaking around the spring, garbage, if it doesn't engage cold garbage, if it won't couple in when it's HOT out idling, garbage, but they don't all go in 5 years. Now if it's 10 years old or 75K miles, then I would say change it, but on the other hand I have had clutches run for 150K miles that still locked in no problems. To me the biggest indicator is when it is cold, try and turn it by hand. If it moves easily, it's garbage, if it has a good bit of resistance to it, then it is probably still good.you should hear it when it fires off. If it is more than 5 years old, it is no longer good.
Two pieces, 4 bolts hold the pulley to the HB. $300 is very high.Isnt it all one piece
They both have rubber in them, and if ones bad, you should do both. Rockauto has them in the DORMAN brand for about $81 + shipping.Ok so the pulley has the rubber correct the rubber split all the way around in middle of pulley
If your already doing a water pump, I would do the 2000 model year pump with a spin on fan clutch, and put in a new fan clutch. The fan clutch should have alot of resistance to it when you try and spin it, not just some.Cool deal it does have resistance it doea not spin easily
Well thank u very much on that so thats good i have a much bigger problem at the moment now harmonic balancer has apperently been split at the rubber all the way around heads of bolts are beat to hell cheapest one i can find is 300 bucks at oriellys any suggestions bc i dont have that kind of cash right now
