quick door question
Detroit Dan
Epping NH
will the front doors from my 93 suburban fit my 97 pickup? Same body style, just dont know if the Sub front doors are different or not.
I would think so. Pull both vehicles side by side..open the doors and compare them....hinges, wiring, ect.
Yes, same doors. The inner panel that all the guts are mounted to did change at some point, but you can modify if needed or just swap the 93 to the 97 IF needed.
What he said :smile5: I think 95 was the change over year for the interior panels..
Yes, the actual door itself is the same, but you will have to swap out the door panel, mirror, wireing, and window regulator. It is probably best just to swap out that entire inner panel.
