Norwegiandiesel
Hi.
Engine in one of my trucks is making a loud "bang". Sounds like a shot bearing, appears intermittenly as, at my knowledge, it should not do if it is a bearing? Sound is like smashing on a piece of heavy metal with a sledghammer? It also seems like it's not running on all cylinders, which also makes me wondering if it's a bearing failure? Don't see why it should not run on all 8 even with a shot bearing?
Pulled the valve covers, no bent pushrods or loose rocker arms. Drained the oil, no chip or alu coloured signs of a seized bearing.
So finally the question is, how much noise is a shot injector or lifter making and how does it sounds like? I've heard that a shot lifter or injector is making quite a sound?
Checked the h balancer, seems ok.
