94DieselSub
Long story short; some of you may remember my dealings with Ted’s Trucks and the two water damaged long blocks I received from them. :BDH:
I finally got a set of 0.030 over pistons, the heads have been done for awhile. I tore down the block last night and found some unusual bearing ware for a low mileage engine. #1 looked like debris went through it, two nice 360degree groves in the the Babbitt with copper showing. #2 mains on the crank has 360degree scratch marks that a fingernail hangs on.
Now here’s the part that is confusing me a little! Both front/rear thrust surfaces of the #3 bearing are showing 75% copper!!!!! Is that normal for a low mileage 6.5? I would think not, since this engine had water erosion in several cyl, I’m really hoping that the crank isn’t bent from water ingestion while running!
Anyone with experience with this, I would greatly appreciate some info!!!!
