chessie 6.5
Just purchased and hooked up GMTD Scan Tech with my laptop and got the following settings: Engine hot idle- Desired injection timing 8.6, Actual injection timing 11.8, TDC offset -2.02
Check engine light comes and goes frequently; Scan Tech indicates timing error. Are these settings advanced or retarded? Truck also requires longer cranking times to start, even hot.
