1tondaully
Ladies and Gentalmen the 6.5L T.D. the motor has 311,000 miles on the motor, it also has never been into except for the water pump, and has had 3 I.P.'S now 4 I.P. with 5 PMD'S with the PMD relocation kit on the 3rd PMD, it has the original turbo charger with everything still original, I had problems with the timing chain and timing on the 6.5L T.D. the timing chain was stretched any where from 3/4'' to 11/2" it jumped time and went into it to change the chain and gears, checked the push rods, valves, compression and everything is good with in limits, push rods straight, valves setting correct, now I need to set the cam shaft timing, got the number one on compression stroke, now I need to know the valves setting to get the valves set correctly. I've timed small blocks and big blocks but it's been so long I've forgotten a lot I'm so sorry, so I need some help please, I need to set the cam shaft is correct for the I.P. will be set correctly.
