Rodd
Recruit
After going 3 years without a 6.5 Diesel I am once again back on the wagon. Not having worked on one in the past 3 years I'm trying to prioritize the mods that need to be done versus what I want done. The only mod that I have that I don't have to pay for is my KOJO tune. When I totaled my truck I had my stock PCM was in the truck so I took my KOJO. The only problem with that is it was tuned for an ATT which I don't have. I also have my heath waste gate controller on my old turbo so I really have 2 mods, but not sure if I should put in the KOJO or not. The PMD is relocated under the bumper as well. Oh, it also has 174k miles.
I'm going to list what needs to be done by what I think is the correct priority. Let me know if you think I need to change the priorities or add something to the list.
Leroys Oil cooler
Leroys Ops Ext
Air filter K&N or Leroy's not sure the difference
Get rid of the pink coolant crap
Change Trans fluid to amsoil
Change diff/transaxel fluid to amsoil
Delete oil filter 90 and add bypass add amsoil
Racor prefilter & change all fuel lines
Leroys Walbro Lift pump
Cross over Pipe
3 or 4" Exhaust
Marine injectors / glow plugs
FTB
Gauges - egt, turbo, fuel pressure
#9 resistor
ATT
I think this completes the list.
Leroys Oil cooler
Leroys Ops Ext
Cross over Pipe
3 or 4" Exhaust
FTB
#9 resistor
ATT
