Nosferatu49534
I've had this issue for a couple months now and it doesn't happen all the time. When I accelerate quickly and then let off the throttle it's almost like the alternator stop pushing power for a second or two. The volt gauge drops about 2.5 volts, maby a little more. I have built new battery, ground, alternator, and starter cables. All the ground connections have kopr kote on them. The hard part is it only does it when I'm driving so I'm not sure if I can do any physical tests to see what's happening. Any thoughts will be appreciated. If it doesn't make sense I can try to explain something better if needed.
